He had a widebody MR2 before the RX7 lol. It wasn't really my taste. Resprayed in pagan gold, black bonnet, sunken wheels, autosalon spec interior.. And less power than mine :P He obviously matured a lot when he decided to modify the RX7!
maybe that was it, either way i remember it was shit as
Any cheaper and I think I'm going to have to consider buying it...love that colour. Drive away no more to mod. Shame he did what so many twits do on car selling websites and put up 11ty pictures of the same stupid front oblique angle...ZERO pictures of the back...and only one of the interior.
lol...maybe it should be, live your life within the confines of the law.
Anyway, enough talk of young girls for now...topic is now chocolate.
I'm thinking Cadbury plain or Coles brand Belgium takes the cake for best block form...and tough call between Guylian and Lindor Lindt for the fine/boxed stuff. No wait, Duc d'O for the mofo win. Too many good ones. Thoughts?
haha cadbury ftw, but my opinion is biased :P
Still have that 10kg block of Cadbury chocolate I won couple months ago. Have no idea what to do with it, cause once its open I aint going to eat 10kg haha. Might donate it to some primary school.
If school donation fails, best answer on SAU wins*
*will probably not win
Isn't it in 10x1kg blocks inside the big packaging? But srsly stop toying with the emotions of chocolate livers everywhere and either eat it or give it away to someone who will lol
Won't that shit (read: heavenly gift from the gods) eventually go off?
haha i think best before date is June/July.
its five 2kg blocks. Need to find a good cause to give it away, unless Ham wants to cook it up for sau? haha
I was thinking the same thing. You've had it a fair while Pat, and I'm betting you didn't buy a custom fridge to put it in :P
kept in temperature controlled area of house, s'all good
I'm on day 10 of anti-fat bastard project and I would kill a man for that chocolate. Literally, I would kill for it. I would cut off a motherf**ker's air supply until he passed away.
Give me the chocolate.
Is Astro Bear gonna have to choke a bitch?
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
