yeah mate here is the link the pics are shit compared to seeing and hearing this thing in person.
http://www.carsales....20903&silo=1011
is this place somewhere near ringwood?
some exhaust place? i remember seeing it when i went to do my epa noise test, but it might be a different car, just curious.
Definitely wasn't a cockfest in there. So much talent!
I reckon bring less cocks next time though. Group of 3 ftw. 5+ is a bit much.
Less does make it easier if the goal is to try and pickup teh ladies.
the place is in south melbourne. yeah i took it for a spin drives very nice.
i dunno 'birds' these guys said they havnt had this car for long but they get there cars from some bmw dealers so it might have been advertised elsewhere.
Maybe they had another silver M3 a while ago and I'm confusing it with this one? Or it could have been a 330CI, because at the time I was checking out M3s and 330s. I definitely recognise the place in the background, so it's either the same car or just the same place.
that's way too much for a SMG with almost 100Ks...
there was a black manual one on carsales also had 100Ks on it was only asking 42K or so for it. don't pay any more than 45K for a e46 m3 unless it's less than 70K and manual.
Most of their pictures are taken in the same spot. Most likely confusing it with something else. Because my mates one, in the add, was parked in the exact same spot, it was a silver 320ci.
yeah it was way too much and with on road costs it would come to 51k. most of them ive seen have very high kays and are still asking alot of money for them.
Billy - got a few quotes for full tune.
Racepace said 800-900
And Trent said 750 ( extra 100 for gtr cos of the front drive shaft) and his going to keep it a couple of days so he can do cold start tune as well.
So yeah booked in :D
easy way to save yourself 100 dorra
drop your own front drive shaft XD
buy a silvia if you wanna go sideways. the suspension design is much better suited to it.
buy a GTR if you wanna go fast.
buy a GTSt if you're broke and wanna go fast.
:rofl2:
Yeah after running a 12.6 basically stock as a rock I'm sure my bro is kicking himself for putting money into his GTST
But meh, thats just drags circuit is fun as well :D
[/inb4 flame]
Also Scott what about a 370z?
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
