:rofl2:
Yeah after running a 12.6 basically stock as a rock I'm sure my bro is kicking himself for putting money into his GTST
But meh, thats just drags circuit is fun as well :D
[/inb4 flame]
Also Scott what about a 370z?
they are way to expensive they cost more than a E46 m3 way to much for a nissan in my opinion.
organising inspections/test drives on these for next week.
http://www.carsales.com.au/all-cars/dealer/details.aspx?Cr=11&R=10243687&keywords=&trecs=35&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294931739%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=0&R=9205456&keywords=&trecs=12&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294922300%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=12&R=9950012&keywords=&trecs=17&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294848651%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?__Qpb=true&R=10337452&keywords=&trecs=12&__sid=12F5A5EA2F87&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__No=0&__Nne=15&Cr=3&seot=1&__N=1216%201246%201247%201252%201282%204294967194%204294967179%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=4&R=10285615&keywords=&trecs=12&__sid=12F5A5EA2F87&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__Qpb=true&tsrc=allcarhome&__Nne=15&seot=1&__N=1216%201246%201247%201252%201282%204294967194%204294967179%20903&silo=1011
Hey Kris, got the 31 back today. New turbo spools @ just under 4k rpm, the lag is not as bad as I thought. Pulls pretty damned hard from my short restricted experience today. Only tuned to 240rwkw, coz the clutch slips with any more. Didnt get a new clutch at the moment (only had the other one just over a year, havent punished it badly either) as I also need to get 25 gearbox & sort out something with tailshaft. The extra power makes the condition of these so much more obvious. I'm happy with it at the moment. If the lag gets to be too much of an issue, I'll put a smaller one in and save this for a dohc motor.
Can't seem to get a broken bolt out of turbo :/ mechanic's tried drilling it etc still won't budge.
He said he has tried the front pipe (jjr bellmouth) on with 5 of the 6 bolts done up and there is definatly no leak, is it okay to leave it like this? I have plans to hi-flow it through hyperflow soon, hoping they will be able to do something about it - will this be okay for a little while?
*insert scared face*
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
