Vic Wasteland Thread
paulr33
well i think i have made my mind up im going to look at a fpv typhoon r-spec soon.
WTF is r spec ?
they stole my nik...
in other news, had a look at 2 audis and a 33r today. gtr was a disappointment :/
probably 40k but could push a little more. and it will be my daily but want to do DECA events and stuff like that.
Bmw 135i? Although they high 50's :(
http://www.themotorreport.com.au/47609/2010-bmw-135i-coupe-road-test-review
But consider this: an FPV F6 won’t handle as tightly, an Evo X won’t engage the driver as much and a 370Z is hugely impractical by comparison.
If you want a car that combines scintillating all round performance with equal amounts of practicality and brand prestige, then the little 135i is quite frankly the best package out there for the money.
Hey guys was gona put up a thread coz i want to sell my Power FC with hand controller for R33 GTR and my twin turbo full setup *standard*..... as i dont know what this stuff goes for i cant really put down a set price and this is a must for the thread.... can u guys help me with what prices i should be asking for these..? the turbos are still on the car and come with hks front pipes
lemme know cheers
George
lemme know cheers
George
would need to know specs of turbos an condition to suggest.
However I can offer u 500 for ur power fc :)
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
