Vic Wasteland Thread
paulr33
i like auto, and if its a bullet proof auto, even better.. so 30-ish, well, if you've got the moneh, i dont see why not,
would you take me for a ride in it though? =D
Well not sure how comfy the boot is yet but sure :P
What are you gonna do with the pics?
people don't need to know about other people's hook ups unless they're somehow involved
Seriously like it's such an achievement...
Keep it to yourself man
if i have to listen to the daily waffling about how great he is with woman i want pics to back it up.
I'd post pics here if it wasn't public. However, you could just ask privately for pics. Birds has seen the last few girls I've been with. I also shared with him some special pics that slappers txted me :P
Yes it's almost like a picsoritdidnthappen type scenario now.
More hot dates than I have hot dinners
I R NOT BELIEVE
Other than that, bored as fk.
Nice day today outside. Was in Yarraville for lunch... Fk the roads there are terrible
So I've got Water pump and Timing belt coming from the states already. Do the tensioner and idler need changing when you do your timing belt? Cant find them cheap anywhere. Kudos motorsport, $200 for the lot including seals etc.
Its a good idea to do bearings at the same time, they can seize up apparently (on Subarus its common)
I just got the Kudos kit best I could find.
definitely a good idea to do it while everything's off anyway. had mine replaced with the timing belt, mechanic used a gates racing kit. theyre on justjap, but like 400 odd for the whole kit from memory...belt, tensioners, etc.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
