Vic Wasteland Thread
paulr33
Mad? lol please.
Just the most overrated Jap wheel on the market IMO.
LOL!
One of the best wheels to come out from Japan :D
The TE37SL doesn't look too bad, i just prefer wheels that are a bit more rare, give the car a bit of personality.
TE37SL are the same, just different colour and yes, rare wheels are great too.
Especially old school style wheels, adds a nice touch.
T & E VERTEX BODYKIT
MIDNIGHT PURPLE RESPRAY (MNP1/LP2)
JDM-SPEC SR20DET ENGINE
HKS GTRS BALL BEARING TURBO
HKS UPGRADED TURBO ACTUATOR
TOMEI PONCAMS (256IN/256EX, 11.5MM)
TOMEI ADJUSTABLE CAMGEARS
NISMO 740CC INJECTORS
WALBRO 255L/HR IN-TANK FUEL PUMP
Z32 AIRFLOW METER
APEXI POWER FC ECU
ARC SUPER-INDUCTION POD FILTER
ARC TURN-FLOW INTERCOOLER
HPI DUMP/FRONT PIPES
HKS HI-POWER CAT-BACK EXHAUST
OS GIKEN BUILT 5-SPD GEARBOX
XTREME 5-PUC HD CERAMIC CLUTCH
HKS HIPER D ADJUSTABLE COIL-OVERS
IKEYA FORMULA ADJ. CASTOR RODS (FRONT)
CUSCO REAR CAMBER ARMS
RAYS VOLK TE37 FORGED 1-PIECE RIMS
Fronts 18x9.5 +12
Rears 18x10.5 +22
Looks like a S14A (Kouki) to me...
S14A fronts look so much better then S14 fronts.
There was a point where that thing was a .5
Also, overheard a couple kids at the shops talking about what cum tastes like, then one of them goes "mahmoud tasted his own cum, he Sed it was ugly"
Lol wtf
I'm assuming you stepped in and corrected em on what man cum really tasted like?
douchebag
douchebag
Nah no way bro. I was hoping you would pop up and tell them your first hand accounts
Aah yes i remember that thread, I'll check it out. I meant as in, that genuine jap drift kind of look, tight fitment, kits etc, know what I mean?
thats mine as it sits presently pretty much
Saw a nicely done silver s2 33 at the gym the other day... Looks like they took inspiration from Billy's car. Nice stance and fitment, spoilerless, roof spoiler etc. I'll put a photo up when I get home from work. Only let down was I don't think they were decent jap wheels but they still looked alright ( I just prefer quality jap wheels on jap cars)
Had a massive dildo gear knob on it too lol
yeh i know it has the lenso d1rs its nice but from memory its NA and possibly auto ?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
