moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem
ya'll get te point
I'm terrified of heights. Kris and his brother made me go :P
I instantly regretted giving in :P
i'm terrified of heights too..
what i do is man up and go for it, once they lock you in, there's nothing more you can do except scream!
Was at Surfers Paradise for Easter. Good Fun
0 - 100km/h in 2 seconds (Superman rollercoaster)
No car can achieve that feeling :(
Brilliant ride. I find that lethal weapon is the most 'unnerving' ride out of all the parks. Hanging buy your ass as you climb up to the first drop.
Haven't been on superman but apart from that pretty much every ride across all of those parks are kiddie rides compared to the stuff at six flags in Cali.
I've never been a rollercoaster person, and went to six flags the day after a big night of drinking, but I went on everything there at least twice. They have the batman which is the same as the lethal weapon, and it's pretty much the tamest roller coaster there.
YouTube Goliath and tatsu, that's where it's at.
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
