Vic Wasteland Thread
paulr33
I'd smash the next queen to be though... Just sayin. She's got impeccable teeth for a pomme. Such a QILF.
:laugh:
Saw this equation on Facebook and half my friends got it wrong. Let's see if people here could pass year 7 maths...
6÷2(1+2) = ?
6 ÷ 2 = 3
Hence, 1 + 2 = 3
? = 3
You're only making yourselves sound like fags by using a cute name like that lol
P.s. Explain your answers boys. One of you is right but I'm sure the working out will be wrong.
Explaining answers bleh.
Numbers inside brackets get multiplied by 2...then summed together...then divided by 6?
I dunno, I didn't do maths past year 10 and I forget anything that happened before year 12. Then first day of uni = hello students you'll now be learning the ins and outs of linear relationships = FML
i had this argument with my missus who is a maths major at uni.......
answer is 9 because
after the brackets you need to work left to right, bodmas is correct but, its bodmas from left to right, ie the left most action takes precedence, because bodmas=bomdas
therefore its 9
Birds, you were correct with BODMAS, but got the order wrong.
Brackets
Division
Multiplication
Addition
Subtraction
6÷2(1+2)
Brackets first, making it 6÷2x3
Next is division, making it 3x3
3x3 = 9
Oh I see now. That makes sense. I always thought each item inside the brackets had to be multiplied by the outside number before summing them together, but that does go against BODMAS if you do it that way.
The creator could have picked a much better equation to demonstrate BODMAS though...you can unfortunately arrive at the same answer with many paths using those numbers.
EDIT: On second thoughts, maybe it's when there's a power outside the brackets that you multiply each number inside the brackets first.
I'm no math nut, but aren't Div and Multi ranked the same? They are however used from left to right?
indeed
hence
bodmas=bomdas
just like addition and subtraction are the same, its just the s sounds better at the end of the word :P
find me a time in any normal engineer's career that calls for laplace transform
only if your an electrical engineer i believe
just out of curiosity, who did you have for maths when you did laplace transforms (IIRC your at rmit yeah?)
Yan Ding.
I can't understand her accent.
Even electrical engineers dont use laplace.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
