Vic Wasteland Thread
paulr33
Am now reminded why I don't play footy most Saturdays...no sleep in f**king sucks.
f**king idiot crashed the merc before i could pick it up
what a f**king waste that thing was an animal. picking up my deposit tomorrow
i cannot be f**ked finding another car dead set f**k my life
/rant
Willing to bet the guy went on a last minute thrash n burn before selling the car to you...makes me wonder how many people actually do that and f**k the car.
Yeah I'm close enough lol. Theres a silver over grey S1 I've seen around reservoir area a bit as well.
Lol where abouts are you from again?
Rimon- that sucks man, not meant to be i guess
way to many stance sites now its just a joke.
stancenation
stanceworks
hellaflush
stanceiseverything
stanceyamum
yeh bad
was posted by a mate on fb
still think its pretty good for a truck, but in US they go nuts for modded trucks there
/rant
that sucks mate but im sure you will find another one.
true, but men with balls drive RWD
and real men with balls and a dick drive evo's :P
9-9:30 is a sleep in when u wake up at 4:30am weekdays. Gotta be at the ground in 95 minutes.
Unlucky rimon
Ya win? Lost by 12 in the last 5 minutes. Only motivation for trying to get into 1sts would be so I can play arvo games lol. But then the midweek training would piss me off.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
