Ok, let me just pull the portable quoting system out of my arse.
No really, hit me. I'll need:
Departure & return date, location/s, dob/s (can have 2 peeps max + children), and any pre-existing medical conditions.
I shall send you a PM?
Or shall I work email? Would that be cool?
My name's not Alex but I sell Landlord Insurance daily. Firstly, what do you actually want to be covered for? Premiums obviously rise as the cover becomes greater and could also be because the company may pay out more claims. So the cheaper quote would either only cover you for basics or they don't pay many claims and can afford to lower the premium. Good for premium, bad if you ever need to claim.
I just want to be covered if the tenants start to fk shit up. No idea on what i need/want. Give me a price around $200-$300 and i be happy haha
Alex, know anything about landlord insurance?
Quotes from RACV and AAMI are like $400, but terri scheer and Property insurance plus want $240-$280?
Whats with the difference in pricing? Is there some clause or something hidden??
Who do you (or your clients) use?
thnx
our office use/recommened terri scheer and EBM when i did property management i preferred EBM, definately go with a dedicated landlord insurer they tend to be better than what normal insurers offer. The biggest catch i found was claiming for malicious/accidental damage can be costly as each item has its OWN excess so 4 holes unless you can prove happened from one incident you pay 4 excess which means it aint worth claiming for.
its all a much of a muchness between those two, id guess our rent role would be a 50/50 split for cover between them
Thanks for the help. Too much shiet to deal with.
EBM online quote came back with;
RentCoverUltra
Features include:
* Malicious damage, Accidental damage or theft by the tenant up to $50,000
* Loss of rent due to a wide range of circumstances up to 52 weeks
* Damage to contents (carpets, curtains etc.) due to defined risks such as fire, storm, water damage up to $50,000
* Legal Expenses up to $5,000
* Legal Liability up to $30,000,000
Building sum insured: not applicable
Contents sum insured: $50,000
Premium: $270.00
PIP still ends up being cheaper at $239
    • Just get rid of the orignal low impedance injectors, replace with modern high impedance injectors, and you won't need the resistors. Wire direct, as per any other engine.
    • Tao, we're not talking about the ECU boost ref. We're talking about the wastegate signal source.
    • Flapping up and down is a consequence of the varying pull on the belt. When the engine speed is suddenly increased, the tension in the belt increases too. When that engine accel changes to decel, the tension is reduced and turns up as a little extra length of beltes between the pulling and dragging pulleys. That extra length flaps up, then down. There's all sorts of other harmonic stuff going on too.
    • hello ladies and gentlemen so i’ve swapped a rb26dett into my r33 gtst and ive come across many speed bumps but its nearly over what im having issues with is the injector resistor box that are normally on the RB26 fuse box but im still using my rb25 fuse box and as a result my injectors aren’t getting power and is the last thing i need to figure out so the car can start. can anyone help me out on where i can find a wiring diagram for the rb26 harness to see where the injectors are supposed to receive power
    • The boost pressure at the compressor cover will be higher than at inlet manifold. lets say, trying to hold 20 psi flat at 7000 RPM. If your wastegate opens at 20 psi measured at the compressor cover, the engine may only be seeing 16 psi. Your base pressure reading at engine would be 20psi by 4K and 16psi by 7K while your MAP at compressor housing still reads 20psi at 7K. For this reason your ECU's MAP source is never on the compressor cover. This difference isn't a major concern if you're using an electronic boost controller (EBC).
