If you're talking about covering your own car, that should be covered Australia wide by the motor vehicle policy. If you're talking about covering a hire car, then travel policies can have a hire car excess waiver to cover some or all of the excess if you have a crash.
what about the other stuff, robberies and shit. lol, falling ill, getting hit by a truck, i dont know. the crap that can happen. someone breaks into the room and steals all my stuff.
How close does your phone have to be? My wall charger can only reach within 3 metres of my bed. Close enough?
Give it a try and see what happens. I normally have the phone charging on my bedside table and it works a treat.
Yeah that's all availble in travel insurance. Medical is a biggy.
Some may and some may not. You'd need to read the PDS for exact details. I know that CGU, who I work for, covers unlimited cancellations on some and up to $12k on your luggage documents, whether they are damaged or stolen. There's heaps of other stuff included as well.
i'll pm you a little closer to the date.
And at mohsen, you jizz on them
i assume they still wind back the clocks on evo 8's too? im looking at one at top secret imports but ive heard nothing but good things from these guys.
yeh can be, but the interior will tell u if km's are genuine
as well as general wear and tear on bushes etc
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
