go 5 stud conversion and save up get a nice set of wheels you can hang onto in my opinion - can always buy a cheap pair to throw on the car when you sell it.
and if you write it off or part it sell me the sunroof rubber as f**king birds attacked mine!
My tyres are getting pretty worn so I'm happy to have the extra weight of a full tank over the rear end.
I personally think that Mohsen should over capitalise on this new Skyline. N/A section is your friend.
Sif you'd fill up all the way anyway. Weight reduction FTW lol. Never had more than 3/4 tank in any of my cars, period.
bahahahahhahaha
its funny cos i think your serious.
bahahahhaahhahaha
do you take a dump before every drive ? you know weight is everything through those roundabouts.
Try driving a 4cyl car with barely much more than 200kw, you feel the difference, trust me!!
Like if I have a 100kg friend in the car the bloody thing just doesn't move. Not like my ZX when I could have 4 passengers and still get pushed back in the seat a bit.
Lol birds you asshole!
Think I'll go multistuds or something. Then again 5 studs would be pretty damn sweet
Cass- how Fkn annoying is it! Going to go for a decent drive after work and get the fuel down.
Edited by Mohsen
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
