Vic Wasteland Thread
paulr33
23kg difference. That's the weight of my youngest brother (minus 5kg). Can definitely feel it.
Weight reduction I couldn't feel: Foglight removal, shaved aerial, lightened headlamps etc.
I reckon about 20kg is where I start to feel it. It may be my imagination though, but I swear I can.
And no, I take them to Nandos coz I'm so baller :D I make minimum wage c*nts lol.
Edited by jezza boii
You car is a ttop ye?
Actually don't even answer that, no point as 20KG is less than 1.5% of the cars weight.
You are tripping if 20KG makes a difference.
100kg (8-9%), noticeable. 20kg (1.5%), not.
It's your own crazy mind making excuses for ... well... fk knows what.
Do you take chicks to Macca's for dates too?
isn't that what everyone does?
lol my gf suggests we go for kebabs most times. f**king keeper
as for the weight saving thing lol fill up your tank man
not running out of fuel in the middle of nowhere > shaving 0.0003 seconds off your highway time
How do you do it? And afford a 300rwkw Skyline, clubbing etc..?? That shit is beyond me.
Anything is easy when you live at home. If I didn't have to pay rent and bills to pay I'll have a rb30det by now
I said 3/4 is the max I've ever put in. It normally sits around 1/4. I put in $30 when it gets close to empty.
Also if it's expensive then I'll only put in about $10 and wait for the price to go down. I only put in $30 if it's cheap.
Weird system but it works for me.
EDIT:
Lol @ tyre/spare jack..... I removed my spare tyre and tool kit the day I got the car :P
So you live life a 1/4 tank at a time?
why do you want a sunroof anyway?
So I can tan on sunny days :D
And Kris how fun is it.. funny when you have no intention of racing but they started it all :P
I'm saving my pay for other stuff.. don't see the point pouring it all into the car I mean I got a PFC and tune so what ~$1500 I mean I can notice a bit of difference but was it really worth it? kinda thinking of just leaving the car now and not spending ~10k on turbos and shit.
TL;DR: I'm poor and can't afford a full tank of fuel.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
