Lol that's cuz I've been there 100 times more than you!
i know. its still new and shiny for me. and i loves it. and i wants it.
The only thing you go to Rock Kung for is duck...everything else they make is shit and overpriced compared to China Bar. Yes the service at China Bar sucks...but the food makes up for it.
lol china bar is overrated. there are other places on that strip that have good food at slightly lower prices.
attacking my brakes this weekend. who wants to help?
Better be putting some nice slotted rotors on there!
slotteds, new pads, new fluid, and painting the calipers if i can. never attempted something like this so will be an interesting exp
Really not bad to do. Just have to make sure you bleed the brakes properly. Otherwise your brake pedal will be spongy as f**k and the brakes won't be working that well lol
I'm bleeding my ABS system on the weekend, so if you want come over. I got all the tools n stuff you'll need.
Also, china bar is great if you've never had proper hawker food... ie if you're white :) You don't go to RK for the service or the hygiene. lol gtfo with your culinary critique, we go there cos its cheap, and is done exactly how they do it in the motherland.
I changed engine (and therefore driveshafts/rotors/hubs/etc) without bleeding - just had to push the calipers open coz someone pressed the brake pedal while everything was out....
Guest
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
