does it have to be something quick?
you could get some nice cars in that range
im gonna get a ba falcon XT bozz auto as my daily
then either rebuild my 33 and bring it back to life
or sell it and get something else quicker later
why dont you just sell the 33 now while you can still get something for it?
doesnt have to be a race car just something that'll keep me amused for the rest of this year. what do ba typhoons go for? wouldnt mind that
it wouldnt be worth $2
your struggling to sell yours and i bet yours is in mint condition
mine has heaps of shit wrong plus 230,000 on the clock
blags
make sure when u cut the wire, leave heaps of room incase u have to rejoin it
and make sure u tape up both ends securely, dont leave it loose
Ladies, or well...Mohsen...and gents...
GUESS WHO IS FINALLY HOME :D :D
ok cass... you win ;)
Miss my old R (the 33 that it is) a lot
the armco didn't...
BBBBBUUUUUUURRRRRRRNNNNNNNNNN
Lol im so awesome I have my own category.
Looking good Cass.
Peeps. Bank cheques. I'm not really experienced with bank stuff n all do would like to know how long does it take for a bank cheque to proces?
Thaaaannkkss
If anyone knows someone with an R32 LHS front upper arm and lower arm PLZ let me know asap
I might have a whole left front assembly (it could be right, would need to double check haha)
Need HELP!!!
Have the ECU pulled out but don't know which wire to cut for speed limiter!!! How are they numbered!!!!
why do you need to go over 180km/h?
You will most likely fark up your hicas and sensitive steering if you chop the speed signal wire from the ecu. (basing this off r32)
He's gonna be doing track days....wouldn't want a speed limiter...
who doesn't get a HICAS lock bar anyway...
theres a lot to learn about entry/exiting corners before you start maxing out the speed limiter. A lot of people jump in, max acceleration down the straights and then f*ck up on the entry of the corner as they coming in too fast or brake too long coming off the straight.
Best to learn technique before going 200km/h+. A beginner will be able to get a better time if all the motions are smooth. Catching up time down the straights seems like a quick win but it aint going to do any favours at the end where the corners are.
My 2cents.
edit; sensitive power steering will be affected when the speed sensor wire is chopped. ECU doesnt know the speed and makes the steering stiff.
  • Like 1
Guest
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
