Not keen to sell his car then...oh well.
I do find this strange that you ring ppl about their cars and they couldn't give a f*k! pisses me off.
We get sick of timewasters. Hard to seperate genuine from timewaster.
seriously f**k my life f**k my luck f**k everything
buyer gets the banstick on ebay.. WTF flamin mongrel didnt even leave a number and we were supposed to meet up on thursday so i can get my cash and he can get the car! hope he gives me a call tomorrow.. not holding my breath though
If it makes you feel any better I got f*cked over too Mohsen.
fkn diggin 32s heaps lately, what happened to it?
what happened to what?
good ol' 32's. I need typeM skirts, roof spoiler, boot lip and moar lows. Need to fix up offset on the front too. Easy fix is spacers but ive had troubles with them in the past with constant vibrations
apparently his dads business account so its important to get no neg reps
Think you're thinking about Moshen...we're talkin bout the nice 34 GTR that only wen't to ~$40k
Dezz, even with 33gtr rims they look the business. Have to be lowww though
Yeah abu's looked good on 33GTR's and low...
that black one looks real nice, pretty much how I'd wanna do one, maybe different wheels but have to be good fitment..
Looks like some custom headlights on it too..
oh my bad, did the gtr sell for 40k? or nah?
pat - i mean did is it from melb that black 32, did it get sold etc?
oh nah owned by this guy
http://www.skylinesaustralia.com/forums/topic/119761-r32-pix-only/page__view__findpost__p__5716327
did the $500 less people not come back then ?
It would never have sold for '$500 cheaper' anyway, they were out to f*ck me over from the start.
Lesson learned, no going out of the way to help anyone from now on. I'm too f*cking soft.
You might live to regret that unless you sell it in the near future...The longer you keep it the more it'll depreciate, as well as any maintenance and rego expenses.
Sometimes it's better to bite the bullet and move on.
last worked yesterday, gave it a high pressure hose but not in the engine or anything .. oh had sway bars installed last night cant see that having an impact.
probably just knocked the cable going from the PTU to the coilpacks a bit. engine moves when under load, just enough to cause a break in signal.
Guest
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
