140 would be max. But u may find it a bit cooler on the track with 2 laps. We r talking about 5mins max on load. Not. 10-15 min moutain run.
No cooler is not ideal, but safely safely as she goes would be the plan. Catch tank for gtr is what u want tho, from what ive seen the stockers blow a bit (5-6 have done this, u end up with oil dripping from the pods)
My gtst never got over 100deg with the cooler.
Hamish that is hawt!!!
Also i run down a smurf, ran him through the blender and he is know lubing my gearbox :P
so anywhere in the first section is fine? see below pic:
max ive seen it go up is like 3/4 through the first section bit.
Martin said bring a stock GTR and win a trophy by default as most are modded haha :D
Cool :thumbsup:
In other news, wanting to go to winton next month for sau championship - how hot can my engine oil get to safely? because I probably wont have oil cooler installed by then so was thinking of doing hard lap then 2 slow ones or something? or am I being to soft I do notice the gauge go up a fair bit during a hill run when i'm not even pushing the car that hard at all is 140 ish safe to be running on?
hey, im planing on doing winton also dont know how hot the car will get there........but after running it at calder on a 26 degree day and seeing the temp gauge nearly hitting 150 will deff be putting in a oil cooler
all my 6-7 laps were flat out no break fade no real loss of power the car is running motul 300v like john said prob safer doing 2laps on /off but i couldn't resist the speed the car didn't seem to mind too much but wouldn't do it again! mmaybe
my gearbox love's smurfs blood give me more!!!
well, i wasn't broke till i went back to singapore, and lost my waiter job because i left for too long a time..
but yeah, i'm a broke gt-r owner.. a happy one though, just broke..
And i'm saving for a trip to f*kuoka in dec, to have the BEST takoyaki in the whole f**king world.
aight
on the phone to autobarn and the guy put me on hold so im listening to the guy advertising bla bla and they had pokemon music playing in the background
like, when you battle.. that dramatic battle music lmfao
Guest
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
