yeah buffer underrun was nasty
do you remember the princo cd's
such coasters from them
they were the first $1 blankies to come out
back when kodak gold's were $5 each
i think when i first got my burner kodak gold 1ea was $25
haha
thats insane
haha
thats insane
Remember buying Dual Layer DVD's when they came out. $25~ for a blank. Was shittin brix when burning PS2 games, hoping for no underrun popup.
looks like rappers are starting to soften up in order for their tracks to actually get played on the radio. snoop dogg, jayz, kanye west, eminem etc
err... when were any of those guys hard?
snoop was the only on of them that's ever been anything but top 40
he's a beast. haven't played his stuff in a while though. the game and fitty are fkn animals listening to their stuff gets ya fired up. true wiggas right there
Agreed
Waiting for 50 to get his shit together again though, seems to be dropping the ball...
been thrashing Game's mix tapes, there's some f**kin sick tracks on em..
i've still got my old yamaha 2 speed burner and some kodak gold blank cd's somewhere in the garage.
back in 96 i was downloading mp3's off irc and newsgroups at the local library, then chucking em on spanned floppies using ARJ, come home with this stack of floppies on my bike, burn custom compilations onto CD's, then flog em at school for $10 a pop. Sold enough to recoup the $600 I had to spend on the burner and not have to work during the hols. Then some other kent bought a 4x burner and started copying my CD's and sellin em for $7.50, so I had to drop to $7.50 and specials like 2 for $12 n shit.
ahh the good old days.
I found an old floppy labelled porn gif's and I was like all nostalgic n shit. Found a floppy drive, hooked it up to my PC, then loaded the image and the pics were like the size of the avatars we use. and in 8bit colour. FFFUUU.
kunt's too busy acting now or someshit :down:
no no, snoop dogg>jayz
negative
game at supafest...tempting
next month yeah? hmmz
I'm all about ~90s rap.. I don't listen to much else (rap wise)
true. game and 50 are the only modern ones i like
Guest
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
