im using the powerfc boost kit and it works well
when you use it you get boost print out on the hand controller and the powerfc will correct based on boost as well
set and forget and away you go
set target boost, set duty to reach that level and your done
it doesnt do dual solenoid or any fandangle stuff
so if your on std turbos etc its fine
if you want 3.6kgcm2 of boost with instant scramble then get a dual solenoid unit
Ok...
So a Power FC does a boost controller built in?
i wonder how your 34R would go with 4.11 diff gears
how do you find its acceleration at the moment with std diff gears scotty
well i dont have anything to really base it on but its definitely quick. for a 6 speed the gearings are very close together. i can be in 5th doing 60km/h and still have enough pick up to get to 100km/h quicker than alot of little cars. i find first gear to be very quick and 2nd gear is the fun gear because if im on fullboost in 3rd im going well over any speed limit.
that probably didnt answer your question lol. if you have any specific questions about it i can answer.
A question for wasteland, I have never changed the pannel filter in my gtr and was thinking about doing it this weekend, I have a sticker on the airbox saying nismo filter, I was wondering if there are any markings/branding on the filter itself to let me know that it is actually a nismo/k&n filter?
the powerfc has the logic and code built into the unit for the boost control kit
but you cant use it without the sensor, harness and solenoid
the menus are on the hand controller etc
the boost kit itself includes
an additional wiring harness
a map sensor
a boost solenoid
on the the side of the powerfc is a white socket, you plug the harness in there and plug in the map sensor and solenoid
so you dont have to do any wiring or splicing etc, just plug and pray
then set boost on the menu and duty and your done
the AVCR uses the same parts but has different controller logic
the avcr has boost scramble, boost gain etc and other features
but it uses the same sensor, harness, solenoid
you can mix and match them (the parts)
No. It's a seperate add on piece.
a map sensor
a boost solenoid
I see, cool thanks!
nah most agents drive bmws/lexus/merc/audi well the decent ones the average ones drive mazda's/honda's etc
i just need something suitable for towing and i dont see myself in a 4x4 could get a lexus gs430 4.3ltr v8 would probably do the job but not sold on teh look of em
i rkn ve's look tits.
Guest
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
