wow that sucks rimon.. hope it gets sorted
astro- fkn lol
grant, gun grey s3 R33 GTR http://cgi.ebay.com.au/1997-Nissan-Skyline-TURBO-V-SPEC-R3-GTR-V-SPEC-Grey-M-/390300486754?pt=AU_Cars&hash=item5adfb8cc62
Meh I dont like that colour..
Black
MP
White
Blue
it's usually a % of the pay out value...ie if the repairs cost $x amount, and the value is $x amount, if the cost of repairs is more than xx% of the value of the car, they write it off
my brother knows a repairer who might be willing to pass it on as a write off. see how it goes
astro- fkn lol
that colour looks queer on 33R, its too gtst'ish
silver 33Rs on black rims looks best imo. i don't care much for that midnight purple either only looks decent on 34Rs
Have 9 tyres/rims stacked ontop of each other, decided to pull down the wall of rims. Pulled off 5 rims and was confronted by a massive possum sleeping in between the rims. No idea how he managed to squeeze through each spoke of the rims to get down so far in the column of rims haha
Ive jabbed him with a stick but he aint waking up. Will wait for him to crawl out before i dismantle his house
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
