Go to YouTube...type in "soccer".
Soccer players take dives, no shit. It's no different to 90% of high tackle/holding the man/push in the back free kicks in the AFL. They exaggerate or in some cases flat out fake it in order to get a free kick.
Sometimes fouls go unnoticed without the exaggeration, so you do what you have to do to make sure they don't.
alot of those might look like dives in soccer but you'd be surprised. go play competitively on grass surface then have someone's legs moving all around you while you're running with the ball. 8 times out of 10 you'll fall over even if no one touches you.
We pay the rego they don't. We get priority lol
fkn lol
So calling you a douchebag throughout the day makes you feel loved? Geez someone calls you honeybunny ONE TIME and it's going to be all *stalker alert* :ninja:
With some people, it's all about the tough love.
Problem?
Btw, think I used to see you on Edgars rd a while back
Nah man no pancakes last night, tbh I hate the pancake parlour they charge like $20 for some pancakes and icecream .... seriously .... it would cost them less than $3 to make that stuff. That and I was a broke ass sob last night had like $8 left in the bank till today when i get paid :S
in other news
this
http://www.news.com.au/breaking-news/scavenging-pensioner-cut-off-georgia-armenia-internet/story-e6frfku0-1226035145555
loooool
I always do. Work is so damn boring.
While I'm bored, if anyone has ever felt the want to anonymously abuse me, now is your chance. Give me your worst:
http://www.formspring.me/JDMR2
Edited by jezza boii
Yeah, but you've got balls Hamish :P Some people prefer to hide behind a keyboard and anonymously hang shit on me, to make themselves feel better.
I believe everybody should be entitled to that right, so I give it to them.
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
