because its a 4door, his mates can go in the back easily.
They were, during the test drive. The guy can't drive manual and had never driven a Skyline before mine. Only one he'd looked at and decided to buy it on the spot. Lucky me, hopefully he doesn't write it off :(
was he able to get out on the road without stalling? imagine if he wrecks it the moment he takes ownership of the car...
It's hard to stall an auto :P What I meant is he's buying my auto Skyline specifically because he can't drive manual.
I even showed him how to use Tiptonic mode but he wasn't interested hehe
Edited by llama_au
2 points to the person who spots whats wrong with this image
lol... bullets havent even been fired
They're so hard they don't use guns to fire bullets they just stick em into kunts.
:rofl:
best post from rimon in AGES
oh yeah, yours is an auto, either way, its good for cruising if its an auto, great for his mates, not a p plater i hope.
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
