I'd be pretty damn happy if I was 35 and still banging a 15 year old lol. Well maybe 18 would be better, but still.
Not sure what's worse, the fact that you'd be happy to be banging a 15 year old, or the fact you'd be happy to do it when you're 35...
wow the owner of that R33's lil brother goes to my sisters school, he had an orange R33 before this.
hahahahahah
so i get a call from a guy asking if ill take 7.5k for the car, f**ken oath! then he goes hell come around and leave a 2k deposit. f**kING SWEET
then he asks if he can take the car and pay me with $500 repayments per week
i told him to go get a loan and come back.>_<
lol poor Jez.
You peeps need to talk to more old people and ask them what they would do if they could spend one night at your age. Sexing a hot, young, only just legal girl is almost always number one on the list. If you think you won't turn into that one day, guess again...only you'll be at an age where you can't.
Fortunately some of us will have memories to stave off any regrets in that department...
Life is full of opportunities...you're only cheating your own desires, conquests and memories by passing them up because of what other people think about what you do (usually a lack of their own fulfilment). This applies to anything you do in life. But hey, more for us if it's not your thing :D
$26,000 price drop.
Car is boss, would so snap it up, but mortgage owns me :(
Any cheaper and I think I'm going to have to consider buying it...love that colour. Drive away no more to mod. Shame he did what so many twits do on car selling websites and put up 11ty pictures of the same stupid front oblique angle...ZERO pictures of the back...and only one of the interior.
that would only end up with me in jail
lol...maybe it should be, live your life within the confines of the law.
Anyway, enough talk of young girls for now...topic is now chocolate.
I'm thinking Cadbury plain or Coles brand Belgium takes the cake for best block form...and tough call between Guylian and Lindor Lindt for the fine/boxed stuff. No wait, Duc d'O for the mofo win. Too many good ones. Thoughts?
Guest
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
