Vic Wasteland Thread
paulr33
What the f**k is wrong with half the people in here!!
I missed out on a lot tonight and don't know where to begin.
1. A man should get a haircut about once a month. I mean really, who the f**k straightens their hair, your not Justin Beaver or David Beckham circa 1999. Grow up and get a haircut.
2. I've been going to the gym for many years, off at the moment, dislocated shoulder... I've lost heaps of size. I don't tell people I go gym, I don't make a big fuss of it, nor do I or have I had any supplements... I do it for myself because I wanted to be stronger for the sports I play.
3. People posting pics of themselves topless are douchebags... Unless your a chick. Honestly, no excuses unless it's holiday beach pictures or something.
Seems to be more muzzas on here than I thought.
Reeeeeally? Interesting, did you go to the same place and did they use the same product? I know that there are a few out there. My girlfriend who recommended it to me has seriously curly hair naturally and she's had hers done perfectly for years. We both went to a place call SUI in the city on Bourke Street :)
Same place, I think it was the same product but a different person doing it. First time around - awesome, however still needed to use a hair straightner but not as much. Second time around hair went dry, frizzy, all broken on the top, permanent kink in it etc. I think it's kinda put me off doing it again. I have to straighten my hair every day but only spend between 5-20 minutes because I seriously cannot be bothered with any longer and I don't care enough.
Ah that sucks :( I was paranoid about mine (would look stupid with short hair) but thought my girlfriends was a good example. The ends are a bit split from having foils done years ago which I know can make a difference but the rest is fine. I guess only time will tell :)
Quoted for truth.
I was learning to drive manual in a car with a short shifter and a leg breaking clutch...and 255rwkw lol
Was strange then getting into a car with a normal shifter and a nice easy clutch. Actually I found it more difficult.
Guest
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
