Woot. Coils, sways and hicas lock goin in tomorrow. Can't wait :D
How did you survive this long without any of those? I mean, stock suspension for superior acceleration, but no hicas lock or sways? them's cheap easy first mods mang.
the joys of buying from the US and getting a cd player for half price shipped than what you get here :D
where from?
i need a single din headunit with usb mp3 capability...
that panasonic in my car is getting dated, cds, pffft, who uses cds nowadays..
got one for the golf too during their Black Friday sale thing. lol @ local shops, even with their christmas sale couldn't match it.
Only sucky part is that the US uses some homo Digital Radio frequency, whereas Australia uses a good quality frequency with a higher sample rate... which means buying digital radio tuners from the US isn't gonna work :(
I still use CDs :P If I plug my iPhone in it tends to go flying whenever I take a corner quickly.
So it's never actually flown then?
I've got a stack of SD cards, picked up 20 512mb ones for like $20 off fleabay. They're slow class 1 or 2 SD's but fuck, all they do is hold MP3's. Takes up little space and easy as to put music onto and you can leave it in your car.
That way I have a different SD for different genres etc.
so cant use the radio then?..... nothing you can do to increase the frequency anyway?
this is the model i was looking at anyway
http://www.kenwoodusa.com/Car_Entertainment/In-Dash_CD_n_DVD_Receivers/Double_DIN_Receiver/DPX308U
well turns out the cd player will work as long as the FM frequency is in the Australian frequency range of 87.9MHz - 107.9MHz it'll be fine and this one is
apparently the AM is shit but no one listens to it anyway
of course, but its regular payments so financially the ghd would be a better long term solution.
wtf? homo
jeez, dont you know;
Power > *
/troll
peasant frequency FM is fine, US and AU are the same. US Digital Radio is different to AU Digital Radio tho, just like them backward nga's are still running around with CDMA phones in half the country while we're cruising mad 3G's.
Guest
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
