if i have to listen to the daily waffling about how great he is with woman i want pics to back it up.
I'd post pics here if it wasn't public. However, you could just ask privately for pics. Birds has seen the last few girls I've been with. I also shared with him some special pics that slappers txted me :P
Yes it's almost like a picsoritdidnthappen type scenario now.
More hot dates than I have hot dinners
I R NOT BELIEVE
Other than that, bored as fk.
Nice day today outside. Was in Yarraville for lunch... Fk the roads there are terrible
http://cgi.ebay.com.au/Mitsubishi-Lancer-2005-Evolution-VIII-/170629852129?pt=AU_Cars&hash=item27ba54ebe1#ht_500wt_898
cheap, but wether can bring to vic without probs because is on nsw revs system
Why should it make a difference?
So I've got Water pump and Timing belt coming from the states already. Do the tensioner and idler need changing when you do your timing belt? Cant find them cheap anywhere. Kudos motorsport, $200 for the lot including seals etc.
Its a good idea to do bearings at the same time, they can seize up apparently (on Subarus its common)
I just got the Kudos kit best I could find.
definitely a good idea to do it while everything's off anyway. had mine replaced with the timing belt, mechanic used a gates racing kit. theyre on justjap, but like 400 odd for the whole kit from memory...belt, tensioners, etc.
Guest
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
