I didn't say exact figures. But go hit up wikipedia to see that my car makes 182kw from factory. Now factor in big SMIC, boost, zorst, fuel pump etc.
Without a doubt it would be 90+kw more than the NA.
side mount doesn't increase power
fuel pump doesn't increase power
I still haven't met Mohsen.
Thank f**k.
More posts like this please Jizzy, and fewer extolling the power-adding benefits of your fuel pump.
Its ok we too busy celebrating our very recent cup win over you queers
Pfft no one cares about the Copa Del Rey. I bet you follow Juve or some shit too :nyaanyaa:
Don't think it's possible for anyone to give less of a f**k about the royal wedding than I do
I disagree. I care so much less that the thought didn't even cross my mind until you mentioned it.
Thanks douchebag.
i dont care much for the weddding, having said that its a pleasent change from all the fkn doom and gloom sick of the depressing shit.
but i dont read papers/watch news programs i find its to much of a negative influence on me.
Guest
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
    • $350 for a skid pan is a joke, cost of living is definitely more in NSW 😂
