I'd smash the next queen to be though... Just sayin. She's got impeccable teeth for a pomme. Such a QILF.
:laugh:
Saw this equation on Facebook and half my friends got it wrong. Let's see if people here could pass year 7 maths...
6÷2(1+2) = ?
6 ÷ 2 = 3
Hence, 1 + 2 = 3
? = 3
You're only making yourselves sound like fags by using a cute name like that lol
P.s. Explain your answers boys. One of you is right but I'm sure the working out will be wrong.
Explaining answers bleh.
Numbers inside brackets get multiplied by 2...then summed together...then divided by 6?
I dunno, I didn't do maths past year 10 and I forget anything that happened before year 12. Then first day of uni = hello students you'll now be learning the ins and outs of linear relationships = FML
i had this argument with my missus who is a maths major at uni.......
answer is 9 because
after the brackets you need to work left to right, bodmas is correct but, its bodmas from left to right, ie the left most action takes precedence, because bodmas=bomdas
therefore its 9
Birds, you were correct with BODMAS, but got the order wrong.
Brackets
Division
Multiplication
Addition
Subtraction
6÷2(1+2)
Brackets first, making it 6÷2x3
Next is division, making it 3x3
3x3 = 9
Oh I see now. That makes sense. I always thought each item inside the brackets had to be multiplied by the outside number before summing them together, but that does go against BODMAS if you do it that way.
The creator could have picked a much better equation to demonstrate BODMAS though...you can unfortunately arrive at the same answer with many paths using those numbers.
EDIT: On second thoughts, maybe it's when there's a power outside the brackets that you multiply each number inside the brackets first.
I'm no math nut, but aren't Div and Multi ranked the same? They are however used from left to right?
indeed
hence
bodmas=bomdas
just like addition and subtraction are the same, its just the s sounds better at the end of the word :P
find me a time in any normal engineer's career that calls for laplace transform
only if your an electrical engineer i believe
just out of curiosity, who did you have for maths when you did laplace transforms (IIRC your at rmit yeah?)
Yan Ding.
I can't understand her accent.
Even electrical engineers dont use laplace.
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
