cos everytime we had a track day the guys with skylines who came last would go back, sell their skylines and buy Evo's to compensate for their lack of driving skills.
Haha!!
Harden up and learn to drive a GTR!
Fark, SAU is laggy as fark!
The whole new server switch over!
That's probably on of the coolest P Plates I have seen.
Surprisingly, I think the Gov put up add to encourage to 'customise' your P Plate.
Interestingly it is not 'De Facing' it.
Those wheels are FABULOUS!
The P-Plate has to remain in its square red/green box. That shit would get you defected.
lol got back from cadbury interview. As tempting as they are I think ill decline them as its rat to the other company who signed me on when Cadbury rejected me from their grad program.
So its sort of payback? haha
I'll tell them give me a call back in a years time.
~_~
lol i ended up taking the cadbury job.
lol that's what my P plate used to look like on my R32 in 2000. 3 years n a cop never said a thing about it.
and the wheels are SSR Vienna Dish... close :blush:
Guest
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
