Need tyres first
My car is setup for
17/45/245
Have Hancooks on at the moment road noise is shocking
Looking at New Bridgstone Potenza
or
Yokohama's
Urgh the road noise I have is horrible!!! Stupid P plate bogans putting some crap called 'Triangle' tyres on a new car >.< Literally you need to raise your voice while you're driving.
Need to do more burn outs and chuck some Michelins on them!
I have my setup sorted out at the moment.
Stock turbo's I have atm kick in at 3300
-5 will kick in at approx 3600-3800
Adding more low end punch with adjustable cam gears and getting it tuned for a bit more pick up in the lower end range.
Rest is good for what I want which is 300kw at the moment. But have the parts there if I want to chase more later.
My car setup is more for Tarmac rally than track I don't want punch from a stand still I want a powerful mid band to rev out to redline, the way I drive the spur with what I have I am sitting at 4000rpm through the spur keeping power up as the car only has 180kw currently and I can keep up with you guys as it is :yes:
As my driving style is to sit in the mid range having the -5 spooling or near ready as I come onto power out of corner increases corner exit speed and provides a lovely 4 wheel power slide/drift.
And yes all handling aspects and braking have already been done and bedded in before adding power to get the car setup right from day one.
The guys at RE haven't steered me wrong yet and the car has been getting better and better as we work through legacy age part replacement, and upgrades where required. My car will look like nothing has changed when they have finished. :D
No Tarmac rally GTR owner is running 370rwkw+ mate. :)
-5s don't kick in @ 3600-3800 either. Yes they start making boost/power there but in reality they don't come on until after 4,000 and it's very noticeable if you've had -9s beforehand as i have.
Don't forget you are seeing a loaded up dyno run, in 4th gear - then ye they come on @ 3,800rpm. I'll check tonight if i get a chance but I think 3rd is around 4200-4400 and even 3rd is 150km/h.
Just because you are sitting @ 4,000rpm doesn't mean you'll instantly be on boost either.
Smaller turbos will come back on boost sooner @ any given RPM. That's just physics.
Each to their own. If i had my day again I'd go back to -9s for street/circuit/tarmac. The extra lag simply isn't worth the power.
On a side note - What ill do if you want is get my car and a mates out, and you can sit in the passenger seat if you want and see for yourself?
Most of my mates with GTR's have -9s on at the moment, so wouldnt be too hard to find someone
Grant! oh wait.. :P
He was running 300rwkw I think though - had good reponse.
Grant! oh wait.. :P
Haha...
Kinda tempted to rape my credit card for pair of these on my new replacment.
Yep 302.8rwkw @ 18.6 psi, which is very nice for street compared to -5s.
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
