is he on the elgrand forum? the aus one... cause someone was on there asking about them as they were going to order them.
we got them on ours with the electronic damper controller and theyre awesome... ive had to raise it up a bit though, especially in the rear because there was no clearance between the rear axle and the bump stops so it was bottoming out on every pot hole and slight bump.
want to get some new wheels for it soon... white with polished lip.
Yeah I think so man, my friends name is Rowan.
+1 for the suspension you got.
That's so good as you can raise / lower the car anytime.
What wheels you getting?
Is that a Supra with a Ford front and rear? :);):D
Looks like its a shortened ford - based on the pics on the photo board leaning on it
Looks like a Fucked up piece of shit!
:D
Hmmmm, now you put it that way perhaps he's onto something.
Empty roads, great drugs and plenty of dirty monkey sex unobstructured by morals.
VOTE ONE BOB BROWN!!!
lol yeah let's heed Bob Brown's preachings.. cull the population, distribute free drugs, regress towards primitive creatures etc
Yeah, when I get off my P's. I'm tossing up between an MR2 turbo, R32 GTS-T or GTR.
Would love to sell the Supra now but being sensible and holding on... 10 months left now.
I see, finally thinking ahead properly :)
Sell the 300ZX and Supra and work out how much you will have and go from there.
man keep ur car its the secks.
Haha!!
Yeah for sure Alex!
Not selling it.
Just saw the F1 car and supertaxigoing around Albert Park then...
I :ermm: at the V8 super car add when they used the singer Pink to promote it.
So AUS needs a mega lesbian chick to advertise for V8 super cars..?
Must by say something about V8 super cars...
Guest
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
