Ok, let me just pull the portable quoting system out of my arse.
No really, hit me. I'll need:
Departure & return date, location/s, dob/s (can have 2 peeps max + children), and any pre-existing medical conditions.
I shall send you a PM?
Or shall I work email? Would that be cool?
My name's not Alex but I sell Landlord Insurance daily. Firstly, what do you actually want to be covered for? Premiums obviously rise as the cover becomes greater and could also be because the company may pay out more claims. So the cheaper quote would either only cover you for basics or they don't pay many claims and can afford to lower the premium. Good for premium, bad if you ever need to claim.
I just want to be covered if the tenants start to fk shit up. No idea on what i need/want. Give me a price around $200-$300 and i be happy haha
Alex, know anything about landlord insurance?
Quotes from RACV and AAMI are like $400, but terri scheer and Property insurance plus want $240-$280?
Whats with the difference in pricing? Is there some clause or something hidden??
Who do you (or your clients) use?
thnx
our office use/recommened terri scheer and EBM when i did property management i preferred EBM, definately go with a dedicated landlord insurer they tend to be better than what normal insurers offer. The biggest catch i found was claiming for malicious/accidental damage can be costly as each item has its OWN excess so 4 holes unless you can prove happened from one incident you pay 4 excess which means it aint worth claiming for.
its all a much of a muchness between those two, id guess our rent role would be a 50/50 split for cover between them
Thanks for the help. Too much shiet to deal with.
EBM online quote came back with;
RentCoverUltra
Features include:
* Malicious damage, Accidental damage or theft by the tenant up to $50,000
* Loss of rent due to a wide range of circumstances up to 52 weeks
* Damage to contents (carpets, curtains etc.) due to defined risks such as fire, storm, water damage up to $50,000
* Legal Expenses up to $5,000
* Legal Liability up to $30,000,000
Building sum insured: not applicable
Contents sum insured: $50,000
Premium: $270.00
PIP still ends up being cheaper at $239
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
