Was tossing up between the cube and the golf for cheap shitty daily that I could give some epic stance.
Cube 12k purchase price with hookups, almost $6k in mods ($2k for airbag suspension, $1.5k wheels, $1k paint, panels and parts, $1k stereo, tint n all the wanky shit).
Golf $5k plus $6k = 11k which is under the purchase price of a cube. Cube is 2003 model, Golf is 2002. meh, still much more modern and reliable than a clunker of a skyline.
scroll down ya lazy kent there 1k
can you get your mate to measure the centre bore for me on those wheels, might try and wrangle em onto the golf with PCD adapters.
actually... FFFFUUU they're 17's. He can really suckadick asking even 1k for 17's.
finished installing the fuel setup on the ke70.... just need to neaten it up and put some padding under the pump to shhhh it a lil
2lt surge tank, lift pump and 044 out of leigh pidwell's 260rwkw SR powered KE....
think it'll handle my n/a 100rwkw? :P
lol funky.. yeh 17s are fine man lets u go more low.. fkn old schoolers
on a gold id be rockin negative offset 15s
post pics of 5k purchase pls
might just get these instead... should come to about $800 delivered at the current bid.
18x8.5 and 18x9.5 both +45 offset. 8.5 +20 offset gives flushness with the body on a golf, so by my calculations, if I add a 25mm hub PCD converter, it should let me clear struts arms etc, and push it out an inch, which I can then tuck in using some guard rolling/flaring and some camber.
lol actually i dunno what it looks like. I just gave money to my mate Roshan that runs Driftline and told him to snap one up that comes up at the shops or customer cars or whatevers... money talks, they are worth at least $9000 but hard to say no to cold hard instant cash.
Fucking NICE!
Guest
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
