ah ok, the guy at importmonster told me that the offset difference wouldn't matter for GTR?
if the wheels are the same width, but have different offsets, then that's fine.
if the wheels are staggered, and the total rolling diameter of the wheel including the tyres is within 1% of each other, then that's fine too.
anything else will cause issues with ATTESA.
that red GTR looks mean!
so 19 x 9.5" +11 and 19 x 9.5" +21 if i put 255s on all 4 that would be completely fine?, might offer him 2.5k
no. you'll run the risk of fouling on the front suspension as it sits a few mm further in than normal, and it'll be about 1cm inside your fenders, so you'll ed up with flushness fail. you can run spacers if you want, that'll fix your issues, but for $2.5k I'd want it to be fucking on point to start with.
those wheels are supposed to go on V35/V36/Z33/Z34, not GTRs.
It'll work if you run spacers, and I'd only run spacers on wheels I buy for less than 1.5K. Anything more than that and I take my time to make sure I get them in the right offset, or I'm prepared to alter the car to make em fit if they're too epic to pass up.
What exactly is your job description Pat? :P Good pay for eating chocolate or nah?
haha im a process engineer at the research & develop. department within cadbury
Just started so im still going through the induction crap but I put my hand up for as many taste testing sessions as possible :D
Just started so im still going through the induction crap but I put my hand up for as many taste testing sessions as possible ;)
Ah nice. Sounds like a good job.
Well Matt has GTR front end i think anyway including quarter panels(at work cant see pics at the moment)? and seems to fill that out nicely as for rears i thought he had to pump / roll his out a bit 10" with +15 i would of thought they would look hot on a 33 GTR? might give him a cash offer ;) so Matt takes care of his bling bling? haha
On a different note i want to buy one of those 33 GTR rear defuses, carbon fiber <3 $500 from psiparts
they'll look hot, but they won't be flush.
ah fuck it, you'll probably never lower your car to epic stance anyways, so nobody will notice that they're 7mm further in than they should be.
he better be giving away a free reacharound with em at $3700 tho. or at least offer to cup your balls for a solid 5 mins.
Guest
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
