those are the new lightweight TE37's. Broseph status. they shave like a few mm off all the edges etc for that ultimate in weight saving. oh they also reinforced the spokes n shiz.
i want it fairly dark, cause there are a lot of chrome bumpers and parts on the car
and the wheels are polished
heres a better pic of what it changes to in the sun
http://forums.viperclub.org/srt10-srt10-co...s-official.html
omg i just found the best color for my rolla when its painted
2009 dodge viper anaconda green pearl :D
think I've seen it before...
oh yeah, its called dark metallic green by every other manufacturer.
http://forums.viperclub.org/srt10-srt10-co...reen-pearl.html
was ninja turtle green taken?
dont like green cars look ghey unless its british racing green and that just gives u bonus toff points on like an aston martin i should add..
when the suns not on it, it looks like british racing green (i was actually looking into BRG when i stumbled across it)
its an old school rolla ke55 coupe - needs either a dark color or bright vibrate color, like orange or red but id take a dark color before i go orange or similer
and id rather choose a different dark color than black etc
What's the bet that a leb came up with the new Viper colour?
Does it come with factory option 22" chromies?
I'm highly offended that it's just a regular pearl-metallic-flippy colour and not a marble texture pearl-metallic-flippy colour.
saw two vicroads cars (with purple lights) pulling over cars on the eastern freeway! No idea what they were checking for..
Ive only seen them pulling up trucks but they were targeting cars this time
Imagine if they pulled over a skyline
Also yesterday, there was a large police van (smaller than a booze bus) parked under a bridge on the eastern freeway. Then about 10-15 police walking out onto the eastern freeway. This was at 7:30 on wednesday morning with gridlock traffic.
Not sure if it was a booze bus setup, not sure what else it could be. Stopping people during peakhour on wednesday morning towards the city sounds pretty stupid. Didnt know so many people drove drunk to work?? lol
Guest
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
