I saw the whole taxi rank at Ringwood station today being searched by the Taxi Directorate. Made many lols
i hate taxi drivers so much, ive got to deal with there BS everytime im coming home going past the airport.
saw two vicroads cars (with purple lights) pulling over cars on the eastern freeway! No idea what they were checking for..
Ive only seen them pulling up trucks but they were targeting cars this time
Imagine if they pulled over a skyline
I know a guy that works at broady vicroads, talking to him one day he said they will go after cars if they have to
moreso when they arnt as busy on the trucks/buses etc, but if someone speeding or if they have the hint the cars defectable they will
i gave you a hint, it was i drive past the airport everyday.
lol f**k i misread that!
anybody wanna hitch up a cage trailer and drive me to healesville to pickup my sheep? :cheers:
im joking btw.. if you cant pickup the sarcasm
Edited by GTR-boy
a) sheep are f**ken disgusting animals..... but they taste good
b) why go all the way to healesville to buy them, there are closer places
c) you live in thomo, where the fuck do you plan on putting them?
haha i knew, cause that meet that went past i was going meet in sunbury if i wasnt working
yeah same, i was going to meet up with them when they stopped in sunbury but i was in Queensland.
why not just ride them back, it would be alot more fun lol.
nick. they are damara sheep
they have the fatty tail that arab sheep have. up until now we didnt know they even existed here
dudes dropping them off anyway so ill have them for a week and into the freezer :cheers:
the tail fat is the equivelant to bacon to an arab.. mmmmm
so funks, what color should i paint a rolla like this?
http://www.carsales.com.au/all-cars/privat...id=127C02C825D8
atm ive got the SSR mk1's in 14x7 0 offset at the front and 14x7.5 -6 at the back fully polished
and the front/rear bars are ke30 ones (all metal/chromed) and has ke35 rear lights (might do a round headlight conversion to)
so i need a color to suit that
will be on its guts to
hmm, never seen it written anywhere that I have to pull over for anything other than police... Be nice to be told these things
nah this guy told me everything, we did a job for his nephew that passed away and became pretty good friends after it
was showing me all the things they have in the car etc and that, its like a cop car inside (radar, gps, etc) and in the boot they even have portable truck scales, among a fark load of other crap the car was absolutly dumped at the back :cheers:
Guest
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
