It's gotta be a 32R Dezz and you know it! Such a tough road stance. I love a R34 GTR as well... but there is always something about a R32 that just makes you go "mmm"
You'll pay through the nose for a clean one though is the only issue :cheers:
They are appealing to me, but there is the age factor...I'd probably only buy a decent example, or a stock one for less and plan to do what I did to my 33 and more...
There's an absolute shit load of 32R's for sale at the moment though, so it's becoming more of a buyers market...The only ones that will get their price are the ones that don't need to sell.
haha i tagged you in it ages ago
Ah yeah that, that's porn. thought you meant 35GTR
Yeah there are GTR's fken everywhere :cheers:
Age factory is indeed a problem. You'd be looking to buy one that's already had someone dump their bank account into it IMO.
Someone i know sold a mint R32 GTR (heavily modded) for over 30k.
So the exceptional examples are still fetching good money, but then it's money well spent as you'd never need to change a thing on such examples really.
Yeah I saw a few of the better known 32 GTR's for sale not long ago...Archie's I think was up there...all asking big coin, but pretty much everything done...Still, there's 33's going for similar money with all the fruit as well.
http://www.skylinesaustralia.com/forums/19...Co-t298244.html
That looks decent, apart from the color which I'm not a big fan of...
If I did go the 32 route, and chose a modified one, a forged rebuild at a reputable workshop would be high on the list of already done mod priorities..
I've started to consider 33 GTRs myself. I've found that most of them are actually cheaper than 32s! At least on the JSPEC featured list.
It would have to be black though. Was never the biggest fan of 33s but in black they look quite acceptable.
There's a wingless one for like 17k landed and complied.
Anyone know what a 34 GTR wing would look like on a 33?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
