suspension arms bent. maybe my swaybar too, but fingers crossed and i have stock one. fairly easy fix. only a small teeny scratch on the fb thank christ. the bloody front end was painted only last week.
no number plate. it was coming onto the eastern outbound from tram rd. slow car in front, 4wd behind. nudge shiiiiiit bang. the cocksucker stopped about 50m down the onramp and waited to see that i wasnt dead, then took off. i was driving like a f**king granny the whole day goddamnit
these are the people cops should be getting, but im sure the cops would see the car with no numberplates but let it go and continue getting those cars with noisy exhausts instead.
It was completely rebuilt. Billet straight cut 1st-4th gears, billet crown wheel and pinion shaft, new diff bearings, Nismo mechanical 1.5way LSD, hydraulic clutch conversion. Had it in the car for all of a trip from Bayswater to Healesville when the circlip popped off the end of the shaft, lodged itself elsewhere in the gearbox and the car was stuck in 5th gear which made for a very interesting and difficult tow home since the car wouldn't roll ;)
Gearbox was out of the car on Tuesday, landed in Sydney on Wednesday, got fixed and sent on Thursday arrived back in Melbourne this afternoon and I got the car back this evening.
I haven't even driven it yet :) The Pulsar was auto beforehand, I'd been collecting parts for this conversion since November DECA last year when I pulled the car off the road.
Don't presume the worst all the time Shan :)
Respray to me = The paint faded over the last 18 years. Full respray to freshen it up.
Head/turbo condition = Yeah, maybe he has blown the turbo.. But it has a new one now so it's all good? I fail to see a problem.
Trust me I've seen enough dropkicks come through the doors at the panelbeaters to know why someone resprays their cars or changes head and turbo.
NO ONE resprays their car for the hell of it in the same colour it was before. They only ever respray the car in the same colour to cover up something or to fix damage.
If you're lucky, it's cos of faded paint. Worst case scenario its cos it had a frontal, or was a VIV car, or a rebirth. You're just as big a dropkick if you're naive enough to believe the in the kindness of the human spirit when it comes to used car sales. If you believe the worst it makes the seller work harder to sell the car to you, or at least be more willing to drop the price. Don't delude yourself and buy a car with glazed over eyes.
Cops are enforcing the road rules on VicRoads behalf...so yeah they have the power to f**k you up, but they usually only bother with trucks etc.
Saw today two vicroads cars and an unmarked cop car pulled over on the grass section between the eastern freeway. 3 guys talking to each other.
Sounds like they were getting ready to ram more people lol
What are they goin for?
Color pref would be black, gunmetal, white, silver...
white is classic on a 32, like bayside blue on a 34 and midnight purple on a 33.
20k or so for a mint 94 model.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
