bigpond cable 50gb plan, 30+ mbps do i win the internets?
half price ftw.
yeh i hated my old 4 door rear, although it was series 1 looks a little better when you paint the middle garnish. (looks a little more like 32 4 door rear lights still ugly but better)
half price ftw.
Lol if it's in your bros name you don't get half price. You get 25% off stooge lol
more paper..... even if it clogs up when you flush
once you walk away its not your problem anymore, let the next person deal with it
bahahahahahahahhaha
sif you dump in public toilets. that shits offfff
Im after a (legal) gun range where you can try out guns (pistols, snipers etc) Anything like this in Victoria?
I went to one in QLD on Hamilton Island http://www.hamiltonisland.com.au/target-shooting-range/ but trying to find something here
as if bomb public toilets.. nastty u catch rabies in public toilets..
I go bombs over baghdad styles at work. Company paid crapper time FTMFW. Gotta get in before 11am though, cos then its all fresh like from the previous night's cleaners.
I know of some clay shooting clubs around franga ,mornington..beleive there used to be a gun club in clayton somewhere too...Not sure if this what your looking for but...
Im sure if you ask the guys at the Gun shop in Frankston they'd point you in the right direction...
http://www.truelocal.com.au/business/miall...-shop/frankston
bahahahahahahahhaha
who said public? ..... i was talking about at home :P
there is one in Little river on the way to geelong, right next the the paintball field they have there now..... its at the back way off the highway, and a little hard to find if you dont know where your going
been to little river, dont think they have guns to "try". they probably have club guns to use if you join.
i have heard of a rang in melb that does what u ask, NFI where it is though
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
