I wouldn't say a "star" yet :( But in all modesty, I have potential.
This time I've teamed up with a guy from Australian Idol 2006.
I've got a bunch of great songs and with his voice and $5k of recording/mastering I think we can create something farking awesome :P
After that will come photoshoots, a website, and all that marketing bullshit.
Will be a long and expensive process but IF it's successful then yeah, I won't be bothering with $10k cars anymore :(
Yeah sound good.
$5K!!!
Well you know being in a band is an investment.
You played any shows yet?
You either make it or brake it, so play a lot of shows, sell merchandise and EP's.
Most importantly is playing shows, release the EP then worry about all the marketing / T-Shirts / stickers later.
Get your name out there in the local scene, the word will spread, ppl will ask for an EP or download it LOL!
When ppl really like your music, they will want to buy merch (T-Shirt / Hoddie) whatever.
Spend your money on the band wisely, spend on guitar strings, guitars, amps, leads, pedals, equipment as they will all help you make / write music.
Music (band) will show who you are and at the end of the day, it makes you money.
Some bands 'sell out' and only do it for the money some stay true and keep the enthusiasm and make money.
quality cannon ball run 3
chasing a white contach at the start and then it pulls over to a carwash and comes out pink
some sort of stealth white cover on the car that washes off and then it goes onto the car carrying truck while being chased
u still havent sold that bucket nick... i'll give you 8 for it with everything on it.
could use an old shitter to bash around the paddocks at my uncles :rofl:
haha rather use it as my own paddock basher.... although pretty nice car for that lol
get coppers.... iridiums are for teh homo's
yeah bad, mitsubishi recommend iridiums for the evo
changed to coppers (9's) cause of the boost and it runs great
It is. And I'm sick today :)
Gave the Pulsar her first wash for the year. She desperately needs a polish but I don't feel up to it.
im still trying to get over a cold i had earlier in the week. everyone seems to be getting sick atm.
designed this on saturday morning... now building it.
hopefully my maths and calculations works and it doesn't fall on itself.
need to stain the pine and ply with "black japan" and walnut. then let it dry.... was hoping it'd be a lil dryer than it is today though :)
im f**kin dissapointed man
how can this be?
coming from you, it should have some phat fitment and epic stance
on another note
was in the city checking out the windsor..
spotted a guy with an SAU hoodie walking with an indian looking guy(kept looking back at us as though were crims lol). then spotted an R34 GTT with a GTR lip and LMGT-4's
how can this be?
were you drop kicked on your head as a baby?
can you not see the camber on the uprights?
Guest
    • Thanks! Supercheap has a sale on this weekend so might be a good opportunity to get a new one. I do have a decent multimeter so I'll give it a try either way.   Hah, you got me! I do not. All I know is that the battery holds charge and sits at an okay level before I start the car. Doing the full charge and rejuvenation cycle on a trickle-charger seems to not really make a difference to the cold start behaviour. I'll try and measure it during cranking and see what it does. It's likely terrible; it certainly feels terrible.  I'll be happy if it is really just the battery and I don't have to dick around with the alternator or starter motor.
    • how do you know voltage is fine?  quick easy test is connect DMM up and put it on max/min mode, remove fuel pump fuse, crank car for 3-5s, go check min voltage You'd be surprised how many "healthy" batteries are showing under 10v during this test in cold weather.
    • Not properly. You need to be able to dissipate 100 amps or so to doing it meaningfully. You can do it indirectly by watching to see how far the voltage falls during cranking. Unplug the coils or something else to prevent it from starting so you can get a good couple or three chugs. It also helps if you have the multimeter set up reading before you start, and that it has max/min functions. So you can catch the real minimum without having to watch the screen, which often doesn't update fast enough to show the real max/min in dynamic situations. Or use a digital oscilloscope, which can be obtained for <<$100 from Aliexpress (although I'd argue for paying up to ~$200 for a nicer one). A >4 yr old battery will very likely be well down the path to the knackery. Many only last 5-6 years these days. The cold weather lately will definitely make it worse.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
