not a fan :(
hmmm why my name and sig? If your the one that wants the car to be able to drive
the person that ownes it is only selling it
dont know.. so they can send you an EPA letter? :P
scotty-
fkn kesha. shes sick
Sounds like my ticket into ATO licenced chemicals :blink:
Ive heard Isopropyl Alcohol is used to make drugs O_o
We use it for cleaning as it doesn't leave residue and evaporates quickly. It's also a skin disinfectant :sick:
oo i got a reply from Recochem
200Ltr drum of 100% denatured industrial ethanol = $437.25 + GST
Equates to about;
$6.60 per week (3Litrs/week)
$3.00 per week (3Litrs of dimineral water/week)
$9.60 per week
Now is this worth the 30-40kw atw gain O_o
just wondering if you've accounted for the shelf life of ethanol, its reactivity to atmosphere (esp humidity from memory ethanol's eficiency decreases when left exposed to water vapour in air) and also expansion of such a large volume in your garage's ambient temperature.
no one thinks that far ahead, you learn from experience not from preventing it in the first place.
fair enough everyone likes different things. what music do you listen to?
i listen to everything, dance/trance house, rnb, retro, 80s
just not a fan of metal, classical or country
andre rieu
shits rad
hell yeh
yeah, i like justin bieber sometimes.. i have to be in the mood for it ya know
ummm just ghey
thats on a 60litre tank though
the evo only has like 47 i think and only about 40-42 is used when driving before the fuel light comes on
so works out cheaper if i do it :blink: haha
haha you would only need about 2ltrs of ethanol and 2ltrs of water for every tank of fuel.
You can also cheap out by using methylated spirits or methanol (which both are far cheaper than ethanol) and use tap water/rain water/britta filtered water
You will just need to check the nozzle from time to time to see if it hasnt built up with crap.
Good question, I know methanol absorbs moisture so its best to keep in an air tight container. I know methanol is fine being stored for long periods but havent researched into ethanol yet.
Contacted the chemical place for prices for methylated spirit and a 50/50 mix of water/meth
also pat....
$1500 = secondhand HKS2530 kit. Both Nick and I run it and get roughly 80kw boost in performance.
you just spent how much and get 30 - 40kw? and ongoing costs are how much?
yo question folks.....
how much power will an s15 make with basic bolt ons eg zorst, cooler, pod etc
cbf going on ns.com lol
Sif be happy with a few simple bolt-ons Chad :blink: Like Nick said, it's like 170rwkw tops.
Buy something pre-modified or with a forged rebuild. Save yourself money on all that shit.
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
