fuck that, its an SR20. drive it till it dies. then buy another one. This kent and his forged obsession, fuck off with that "I have forged internals" braggery BS.
If you're dailying an SR, boltons are the way to go.
don't u run a 2530?
haha nope, my turbo bigger than a 2530
custom made garret one, uses a 33 comp cover machined all the way out and a AVO .73 exhaust housing
pretty much esentially a GCG rb25 hiflow the size
yeah same goes with all engines, drive them till they need it
otherwise u pay big bucks for nothing
yeah thats the price im looking to spend 18-19k.
At the end of the day all i really want is a straight pipe and gangster fittment.
hah buy a standard one and put straight pipes and hellaflush fitment then :blink:
Haha typical! Wouldn't expect anything less from you :blink:
Will be good when you've got a car again. I'm always down your area now. Can do some carwash meets and shit lol
chad if you gots cash moneh ready let me know, there's always kids comin in the shop wanting to offload cars cheap to pay off loans etc cos they can't afford the baller status anymore. You'll need 16k minimum tho.
also pat....
$1500 = secondhand HKS2530 kit. Both Nick and I run it and get roughly 80kw boost in performance.
you just spent how much and get 30 - 40kw? and ongoing costs are how much?
lol ive already got a hks2530, rebuilt too :blink:
210kw with 15psi @ 11.5afr
I should be able to get 230kw atw with 18-19psi with 98octane
and then ontop of that will be the methanol injection which should get me another 30kw atw
Im hoping to hit 250kw atw
i listen to everything, dance/trance house, rnb, retro, 80s
just not a fan of metal, classical or country
hell yeh
ummm just ghey
he's awesome man... you have shit taste
just get a non turbo car and be done with it..
u been going on about it for ever. its gonna be like the boy who cried wolf by the time u get something..
just man up and take the plunge but go non turbo save ursefl a pulsating rectum everytime u drive for the next 3 years
if this is directed at me; i dont want an NA because i want something i can take to a track and have some fun in..
then again, if they approve it, no pulsating rectum
I want 7.5 or 8 wide at the front and 9 or 9.5 in the rear. Preferred style is 5 spoke but open to suggestions.
depends on the car you wanna put em on.
learn to walk before you try to run dicksnot.
Who said N/A isn't fun.. :whistling:
I have 4 N/A Skylines, the newest one is surprisingly fast. R32 with RB25DE.
Who said N/A isn't fun.. :D
agreed, N/A is still just as fun. are you saying that because its not turbo it wont be fun? im sure a porsche gt3 and ferrari f430 would be very fun lol.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
