Also... this is my inspiration:
the golf has slightly worn factory cream leather interior, which my dad's mate is gonna recolour/restore to a nice tan like the murc.
u know my opinion is the only valid one.
truf!
you're like that voice you hear when you find a passed out chick, which tells you its ok to fingerbang her, because there's a very good chance she'll wake up feeling horny and do you.
yo question folks.....
how much power will an s15 make with basic bolt ons eg zorst, cooler, pod etc
cbf going on ns.com lol
From memory my other half's Jap Spec made 165rwkw with just a pod and exhaust, a nice free-flowing exhaust makes the biggest difference.
Nope. Bare in mind that's with a CES turbo-back exhaust. Made roughly 30rwkw over when it was dyno'ed stock.
It makes 250rwkw now with stock internals, GT2871R, Poncams, Pod, FMIC, Boost Controller, 6Boost Manifold, Exhaust.
17x8 +40 in a 5x100 PCD
FFFUUU this is the smallest offset I can find :wub:
or 18x8 +38 VS SS's
A62859-x02.jpg repaint centre gold?
fucking euro 5x100 PCD screwing my ability to obtain baller wheels cheap.
is titanium taking over carbon?
ahaha nah there are heaps of carbon parts out, more than titanium
but i mean seriously who the hell is going to use this?
http://cgi.ebay.com/ebaymotors/JDM-Lancer-...=item2eaca4cae2
in teh end i couldnt help myself and bought a titanium gearknob
gona get some titanium pedals, and titanium wheel nuts
dont blame ya, titanium is gooooood.
yeah but $1200usd for a used ARC titanium strut brace for evo....... a bit too much imo
there is a engine shock absorber for $300 delivered in titanium - might get it later as i was looking for one
anything evo its good to look in US, they got heaps of shit... even full bolt on gt35/40 turbo kits with dump/front pipes, intake pipes all made up
only thing that gets u is the postage
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
