Would it be wrong to use an aboriginal word as a band name? For some reason I feel like I'm not worthy of using their language because I'm white lol...
Edited by jezza boii
what word do you want to use? im sure whatever it is it will be too hard to say and spell lol.
Alkira. I think it sounds really nice. It means "the sky". My music is inspired alot by the world around me (sunsets, beach, sky etc.) so the name really suits.
wtf... why do cnc'd titanium parts have oxidisation marks on them? that's full homo spec.
titanium + heat = oxidisation = pretty colours
titanium + electricity = electrolysis = pretty colours
titanium + cnc machine = mirror surface in a uniform colour
in fact to make a cnc'd titanium surface go magenta/green you have to etch the surface or subject it to extreme heat, which actually distresses the material and makes it weaker. This happens naturally near welds and shit, but on a machined washer and bolt? GTFO.
those washers are just anodised too look like titanium
i dont see any problems with it, i like it, easy to say and write lol. actually doesnt sound like an Aboriginal word.
id say go with it, you like it and it has a meaning to you and your music.
wtf is with all these shit sizes, harden the f**k up and find something decent.
I dislike the blue but thats personal taste, hate blue.
you find me epic fitment in 5x100 then. I'm trying to avoid running spacers, pcd adapters etc.
they come with 6.5 +30 or some shit.
After all the measurements I did I can fit 9" +25 to 9" +30 in the front with some rolling and so on. This will give me minimum offset on maximum width.
The rears aren't an issue, there's plenty of clearance and space to fit up to 11".
on the rear I'd like around 10" +25 or something like that.
this is the colour the car is atm.
Fucking euro's running gay bolt patterns and reverse mounting hubs.
That's not overly expensive.
Funky - do it right. eBay USA for some BBS's you know you want to!!
yeah i know its not
but atm for me it is haha
fuuuuuuuu
Might explain why my car has been trying to stall when coming to a stop yesterday
ive got a set of gtr injectors for sale :P
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
