ive had a review of the online demo i made for the hand controller
its actually pretty good i think, sure the format is ass, but the functionality is basic and works
http://www.paulr33.com/powerfc-emulator/menu.html
looking forward to someone doing it in flash and doing all the screens
fuuuuuuuu
Might explain why my car has been trying to stall when coming to a stop yesterday
nga wut? that's exactly what my ceffy's been doin... might check the injectors today.
Funky - do it right. eBay USA for some BBS's you know you want to!!
BBS's are cheaper out of germany, my uncle can get a set and send it down.
But I don't wanna just do a Euro/US spec BBS meshie replica. I want to give it that oceanic flavour. Like when I talk to the guys inthe US/UK they always go on about how we get work meisters and GT-C and XD9's on our skylines and shit... I wanna try and replicate that uniqueness.
I'm seriously considering a set of VS-XX's with gold centres in 9" and 10.5" front n back. However I'll need to run hub adapters for those, and that means I'm gonna be nervous as fuck about a wheel coming off, and also more importantly I'll lose up to 20mm of offset, which means I'll have to get like an 8 and a 9.5 or soemthing like that spaced out. Ideally I want something with max width and minimum offset that just bolts straight on.
And Basti's right, I'll never pay full price/retail for something, I'm happier buying secondhand. Otherwise I'd have gone out and bought a brand new golf instead of spending $5000ish on a 2000 model.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
