funky man you know that brown vw featured on hellaflush couple weeks back with lumberjack theme?
that should be ur inspiration smooth as paint work + tough fitment was off the chain!
that car had all the plastics in the panels though... my plan is to shave it all.
so need to make a VIN decoder tool for Nissan Skylines... just ran the dub thru an online tool...
Region: Europe [ W ]
Manufacturer: Volkswagen [ V ]
Car Type: Passenger Car (VW) [ W ]
Model: Golf Mk 4 [ 1J ]
Year: 2000 [ Y ]
Assembly Plant: Mosel, Germany [ P ]
Did everyone see the police hiding in the black spur and using radar to catch mostly bikes?
They even used some basic camouflage, looked like an army operation!
They've been there for years (really I think they live there). If you check the gates at the tank and Fernshaw, if they are open usually it means the camo's are in! Just don't over take on the straights :wub: (much safer, hey)
ok, I've kinda decided...
Gonna get these fail fitment 18" 100 PCD Work Meister S1's:
Then find some epic fitment/size 18" 114.3 PCD Meister S1's down the track once all the flaring and rolling and shit is done, swap the centres out... sell the resulting 114.3 PCD fail fitment S1's for mad money to offset costs and rock epic fitment 100PCD S1's on the golf, thus becoming the ONLY golf in the world to rock meister S1's. And just to rub my massive throbbing engorged penis in all other golf owners' eyes, I'm gonna painy the centre blue like this famous blue car:
Or there's these XD9's:
Fitment is OK, but width is equivalent of a semi, not a rock hard greasy boner.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
