8.5 and 9.5. His were custom ordered 5x100 at the right offset etc. There's no diff between the 2 door and 4 door as far as fitment goes.
I plan on rolling that lip out as well, for extra width, so I should be able to run 9.5" in the front and 10.5" at the back with a little poke, or 9 and 10 with no poke. personally I like poke over pulled fenders, just finishes the transition.
Hey Shan,
We need the rims as samples and it can be 5-6 weeks to manufacture as the heat treatment gets done in 200 rim batches so a bit of a long winded process.
Drop them in and we can have a look.
Who's. Your. Daddy?
All set and ready to go. Now just need to get the wheels from japan to oz, bust em apart and then get the outers machined up.
neg
needs a drift lip at a minimum otherwise it looks aids.
this
FFS... quick search in japanese just came up with this dude in Japan:
FFFFUUUU... 2nd in the world to rock meisters on a golf :3some: just doesn't sound as catchy
hahahaha you sheeeeep!
So I decided to slip at work today with a hacksaw...
6 stitches in the palm of my left hand
Ouch! Claim work cover, my friend got 20g and he didn't even need stitches! One of our warehouse workers at my work chopped his finger off because he dismantled a product stand the wrong way, they couldn't reattach it either because it was inbetween the nail and joint. ouch!
Nah I'm going into work tomorrow. I need a couple of days off next week to sort out a home loan, so yeah, I'll worry about it then lol.
Just means for the rest of the week I'll be doing SFA and getting payed for it :thumbsup:
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
