you have my sympathy however...
i wouldnt worry to much about it, from all my breakups and shit the next girl ive been with was better than the last
there are plenty out there and i wouldnt stress about it, its over move on enjoy life
That's true, but I didn't break up with her because she wasn't good enough or anything.
This girl was amazing. She would do anything me, she was 110% gorgeous, career planned out and a heart of gold... but I just decided that at this stage in life I don't want to be held back in any way. I want to get serious about my music and career (which could be leading places soon).
I also lost alot of friends because I was seeing her instead.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :) Will be depressing sleeping alone and waking up without her.
Wheelspin in every gear except 5th. Yep, fun :)
Awww, I thought I was cool wheel spinning 1st 2nd and partially 3rd :) But mine is NA.. with like 125rwkw.
But hey, that power figure is huge. The power/weight ratio must be insane. How much does the car weigh?
I'm getting my new MR2 in a week or so. Weighs around 1150kg (with potential to shed more) and engine puts out 180kw stock. It's had a few mods (IC, fuel pump etc.) and running 15psi.
Should be pretty quick yeah? ;)
I'm not sure exactly, I haven't had it on a weighbridge. They weigh 1095kg stock. I'd say mine would weigh maybe 1150kg now? Just guessing.
Pretty good power to weight yeah :)
Your MR2 should be reasonably nippy.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :banana: Will be depressing sleeping alone and waking up without her.
i think you have done the right thing mate and in time you will realise that alot more. you need to concentrate on your career alot more for a few years like i have done and it does really help.
all the best with your career, by the sounds of it you will do well. :ermm:
dyno'd the golf at a mate's shop for shiggles. 80fwkw. bahahaha. POS 8 valve 4 cyl SOHC is gutless as. Does 8.5L/100km tho.
Also, factory paint flips from puple to blue, and in the dark looks black. Thing's gonna be a kent to colourmatch.
well turns out the evo has ghey as 1/4's, as much as they look wide you cant fit a 17x9.5 +17 on the rear without it sticking out about an inch
and aint no way im flaring them to suit
why make front guards that fit wider wheels than the rear O_o
oh well have to find something in the vacinity of 17x9 +25
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
