Have you turbo'd the Supra?
No, I have a turbo MR2 now :banana: Picking it up on Wednesday.
Probably won't pass a roadworthy with the dodgy boost tap on it and I want an electronic one anyway. Will only put the boost up when I need it. 15psi for commuting to work is a bit silly :thumbsup:
Awesome!
Selling the Supra now?
Post pics of MR2.
meh..... just leave it up.... your foot is a boost controller.
i daily mine with stiff coilovers + running ~300rwkw.... you just need a brain... even when its wet its not an issue
kris... i see your tbc 300 and raise you another 23 :banana:
e85 is cheating...
I might finally have broken 200 in a few months...at all 4....
But now hamish has made me feel peasant in my happiness at it :thumbsup: damn u hamish!
Awesome!
Post pics of MR2.
Yeah, MR2 will go into the shop for a respray and while it's there I will sell the Supra.
CBF posting pics.. Basically it looks like crap. It's completely stock body in red with some fail spec 17" wheels.
Will soon be black, kitted, dumped and hopefully rolling on some nice jap wheels.
I don't know if I even want to leave it at 15psi though :P It's a stock turbo. What is it meant to be running? Like 6psi or some shit :)
I dunno.. I just don't like having a boost tap.. And a GReddy Profec B Spec II would look nice in the car I think.
saw a hot white MR2 in sydney (chatswood). Full honky spec with CE28N's in gloss red, bomex kit all around (snorkel n all that shiz), flared/rolled guards, dumped low and a thin offset red stripe from the front to the back with some typography designs next to it.
Was shit hot. Awesome use of colour, simple graphic design to break up big mass of white, and epic fitment and stance.
I think I had my first ever MR2 induced boner.
If you're going red, you should do the reverse with white accents.
I quite like the stock Red colour, looks nice.
Good to see it soon.
I've never been the biggest fan of red. Black is more my style :) A nice shiny black.
Man... I'm getting wood just over that description!!
Hmm... Flared guards... How would that look on mine? I'm going for a similar bodykit to last time but more aggressive rear bar and alternate front.
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
