hear is the list of his mods:
Trust T78-29D 14cm installed for quick spool up on the 2,700 engine, very high response even in town driving.
2,7L specification
HKS 87mm forged piston kit
HKS con rod and crank metals
HKS STEP 2 camshafts (264/272)
HKS sliding cam pulley
HKS strengthening valve spring
HKS Head gasket 1.6mm
Dynamic balanced crankshaft
Head ported and polished
Combustion chamber process (squish area removed)
Block bored to run the HKS 87mm forged pistons
TRUST T78-29D 14cm turbine
TRUST racing External waste gate TYPE-R
TRUST front pipe
Trust exhaust manifold
Essential OIL catch tank
SARD 700CC injectors
SARD FUEL PUMP RELAY
NISMO fuel pumps ×2
SARD fuel pump wiring KIT×2
SARD Fuel pressure regulator
HKS fuel rail
EAARLS fuel line
ARC pre- stage - R
SARD low temperature thermostat
Aluminium radiator cooling panel
GReddy upper radiator pipe
FULL STAGE full titanium Exhaust system (custom made)
HKS superpower flow
APEX ECV
HKS TYPE-R 3 layer intercooler
HKS intercooler piping
ARC twin core aluminium radiator
Drive train/Brakes/Suspension:
ATS Twin plate clutch
AP MINE'S 6 pot brake callipers front
355MM 2 piece brake rotors
BREMBO standard rear brakes
SEIDOYA brake pads
Stainless steel mesh brake lines
NISMO 1.5way LSD
PRO Drive 18 inch Alloys
265/35R18 93W - Bridgestone Potenza RE55S (Semi-Slick)
CUSCO front upper arm
TEIN pillow ball tension rods
QUANTUM coil over suspension
CARROZZERIA CD player
Latter-term type projector HID headlights
Racing gear 6500 Kelvin HID (Hi&Lo)
Optional OIL cooler duct in bumper
N1 front bumper duct
N1 front hood top mall
NISMO side step
NISMO rear bumper
Endless FRP Bonnet
HKS F-CON V gold PRO
Blitz dual SBC boost controller
TRUST turbo timer
Defi link controller
Defi oil pressure gauge
Defi Oil temperature gauge
Defi water Temperature gauge
Defi boost gage
NISMO full scale 320KM meter
NISMO gauges
Roll cage (new)
MOMO competition steering wheel
DU-LUCK rear cross bar
DU-LUCK rear floor bar
BRIDE ZETA-III drivers seat
Can't wait to get home. Gonna polish up my exhaust and give my interior a good clean. Getting new seatbelts tomorrow.
I love being able to work on a car again :ninja: Even if it's just detailing. The Supra has always been way too immaculate to change anything.
It looks like it was just overfill :ninja: I'll have a look under it again when I finish work but I'm 99% sure it's all good :banana:
Goes in for the RWC on Monday so hopefully not too many unknown issues.
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
